windows 7 vs konica minolta di 550 question
  • brent
    • Nov 2008
    • 1214
    mykonicaminolta.com states that these are not compatible. but if you go to kmbs.konicaminolta support windows 7 compatability states that the di 550 is compatible with the (in box) drivers listed on the windows 7 chart. is this so? I can not find it in mykonicaminolta.com under the drivers section you can not get a driver for this os and this particular machine. help?
    thanks guys
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    look under the ic chip number.
    • brent
      • Nov 2008
      • 1214
      you lost me mr. spock
      • ck1
        • 485
        try to update the driver at win 7 and see. di 2510 have driver but is PCL5e
        • mascan42
          • Oct 2008
          • 485
          "In-box" means the driver is pre-loaded with Windows 7, but it's probably listed under the print controller model rather than the copier model.
          • brent
            • Nov 2008
            • 1214
            I had a rep tell me that windows 7 would not work on this model.
            I guess we will find out
            brent
            • RRodgers
              • Jun 2009
              • 1947
              brent
              Well, if ya just want to print you can just use the HP laserjet 4 driver.
              • brent
                • Nov 2008
                • 1214
                I will advise the customer. kind of wierd that it would be inbox of the new windows 7 os
                but according to mykonicaminolta that machine is not compatible with this new os
                I have had to use hp drivers in the past. they do work
                thanks
                brent
                • aesthetics1
                  • May 2010
                  • 148
                  Hello,
                  The driver is built-in to Windows 7, that's what 'in-box' means.
                  Screenshot attached for reference.
                  When you are installing the printer, and you get to the manufacturer's list, you have a Windows Update button. Chances are you haven't updated your driver list there yet. Once you've done the update you should see it listed.
                  If you are under a 32-bit install of Windows 7, you can simply use the XP driver. You will get the message that the driver is not digitally signed, but you can continue anyway, and the driver will work just fine.
                  • brent
                    • Nov 2008
                    • 1214
                    if it will work. that will be great. I appreciate all the help
                    brent
                    • Chip Resets SA
                      • Sep 2010
                      • 46
                      Agree with RRogers. Try and use generic HP driver - as long as its PCL 5/6 should work.
