KM Bizhub C550 Size ?
  • scomeau1
    • Mar 2011
    • 100
    I have a Bizhub C550 coming in from shipment and I have to get it thru a small door 29 Inch wide.
    The spec's say it's : 25.5" x 30.5" (without control panel)/36" (with control panel) x 45.5" / 418.5 lb.
    Will this fit and what about the control panel can I flip it up to fit in the 29 inch door ?
    Thanks for any help you can give me.
    Scott
  • emujo
    • Jun 2009
    • 3009
    See this frequently...most cases you can manuver the unit by pushing exit side in 1st and diagonally working control panel through. In some tight fits you might have to remove the screw that locks the control panel in the "operations" mode (comes from factory with CP down flat against main body). Remove couple of white covers near fulcrum point and you should see a shoulder screw. Remove this and pull control panel straight out, then you should be able to lower flat against main body. Emujo
    • RRodgers
      • Jun 2009
      • 1947
      As stated above, you should be able to manuaver it around to get thru the door.
      • scomeau1
        • Mar 2011
        • 100
        Remove couple of white covers near fulcrum point and you should see a shoulder screw. Remove this and pull control panel straight out, then you should be able to lower flat against main body. Emujo[/QUOTE]
        When you control panel straight out is there wires that I have to worry about ?
        Thanks for your reply Sir !
        Scott
