Bizhub C350 Service Mode
  • tmanamore
    • Sep 2009
    • 74
    [Misc] Bizhub C350 Service Mode
    How do i get into the service mode on a Konica Minolte Bizhub C350?
  • Valeo175
    • Apr 2011
    • 22
    Hit the stop 0-0 stop 0 -1
    • tmanamore
      • Sep 2009
      • 74
      That didn't work. Anything else I can try?
      • CT Copier Repair
        • Mar 2010
        • 304
        Yea don;t post this stuff in the publicly viewed areas
        send it via private message
        • pakalo
          Ciao,
          Per entrare nel Tech. Rep. Mode premere:
          Utility->Contatore->Stop->0->0->Stop->0->1
          Per il TROUBLE continuare da qui premendo:
          Stop->9->Stop->0->Stop->1
          Ciao.
          • da2or
            same trouble
            I'm having the same issue. Unable to get into service mode due to error c-d010. I must be missing something as I have tried a few things to get in to service. I cannot get past the first screen, so I'm looking for a power up solution! Thanks, if you can help!
            • CT Copier Repair
              • Mar 2010
              • 304
              I guess that if we can't read italian its ok
              DOn't post this in forums
              come on guys its not that difficult
              B
              • da2or
                Can't get into service mode
                My problem is when I power up with the utility key held for a Trouble Reset and I enter in my service code, I see the flash of the CE Service password screen, but then it returns to the error screen before I can enter in the password. So I am having a tough time just getting in. Anyone have any suggestions? Thanks
                • tritwi
                  • May 2011
                  • 4
                  Hit Utility key then counter then counter details then stop 00 stop 01
                  • chrisban35
                    • Jan 2011
                    • 199
                    Re: Bizhub C350 Service Mode
                    Now that I am in, what is the password? I'm normally a Canon and Xerox tech, so need some help guys. Thanks in advance.
                    • khattab.al.masry
                      • 212
                      Try with the following attachment if password wrong use another 12345678.
                      with my best wishes.
                      • chrisban35
                        • Jan 2011
                        • 199
                        Thank you very much for that information... I actually fumbled around online for a while, and came across a site that used the following... Not sure why it worked, but it did...
                        "1. Press the Utility/Counter key.
                        2.The Utility Mode screen will appear.
                        3. Touch Meter Count on meter count display.
                        4. Press the following keys in this order.
                        Stop a0 a0 aStop a0 a1
                        5. Touch Password, and enter the CE password using the display keyboard or the 10-key pad.
