You can turn on the line monitor and listen to it dial, it should be tone dialing not pulse, you should hear the ring and the other machine answer you should not hear a hissing or sizzling in the background if you do they may have DSL on the same line. Also make sure the default scan resolution is not set to 600 dpi most of the Konica Minolta products use the same default scan settings for both scan and fax most faxes won't receive a 600 dpi image they hang up right after the handshake.
Biz hub 500 fax
Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI Boxes -
Ok guys, thanks a lot. It was the marketing area. The funny thing is, the copier that was faxing fine, has the same settings as this one did. The first thing i did was print a report to compare the settigs. "these are the things"Comment
Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
