FS 503 not stapling
+ More Options
Posts
  • Desert Rat
    • May 2008
    • 1089
    FS 503 not stapling
    On the control panel it sez to replace the staples in which ever stapler I install the
    cartridge.
    On the computer screen it gives a message that the needle is missing.
    I'm told that the needle is a small black piece of plastic that feeds or
    helps to feed the staples. I has to be in the cartridge that holds the
    staples, because the messages follow that cartridge. That cartridge is not
    completely empty. There is a slab of staples about 2.5 inches long.
    Is this a normal "out of staples" condition?
    I was not able to find the needle or where the needle goes.
    Will I have to replace the cartridge that holds the staples?
    According to the parts manual it is supposed to be replaced every 5K staples?
    Each roll of staples is only 5K.
    The book also sez it is not handled as a part. How do I get one or two of these
    items?
    What is really happening with this?
    DR
  • mo0651
    • 1054
    You may have to remove the remaining stack of staples and look for a small section broken off or loose in the staple path of cartridge. Probably a jam. Had one of those try that on me 2 days ago!
    • Desert Rat
      • May 2008
      • 1089
      mo0651,
      Thanks for the tip. What's the trick to getting them out?
      Would a thin piece of cardboard be able to push them out?
      DR
      • mo0651
        • 1054
        maybe a flat letter opener.
