bizhub 7272 e-mail editing deleting
  • sdelgo
    • Jun 2025
    Our office has a bizhub7272 with an IP 511a installed for scanning. Is there anyway to edit/delete already entered e-mail address on the copier? I tried from the copier and also from a browser using the ip address.
    Thanks,
    Steve
  • aesthetics1
    • May 2010
    • 148
    This is very similar to the Di7210 etc models we have in the field. The way to change those is to go into the "Help" mode from the main copy screen, and then into key operator mode, and to option 19 which I believe is "scanner transmission setting." From there you can edit the addresses. I'm sure the method is very similar on the 7272.
    • sdelgo
      worked like a charm... thanks much!
      • aesthetics1
        • May 2010
        • 148
        No problem! Happy to hear that worked.
