Changing the line frequency
  • bizhub1
    • Sep 2008
    • 230
    Hello, have a customer that has a KM C353 with a Fiery IC 409 on it and the customer wants to change the lines per inch for prepress applications with Corel. Can not get the machine to change line frequency no matter what settings. Wandering if anyone has ever dealt with this, customer says he used to have a cheap printer that would do it. Thanks
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    I have run into this same thing customer had an old hp that only printed at 300 dpi so you could always see the dots when printing half tones like photos, they want the new equipment to perform like the old so they can make some thing for an old plate maker that needs to see the dots. The answer is no the new stuff prints at 600 dpi or at worst 400 dpi with smoothing so you are not going to see the dots ( at least I could not make it produce dots), most people want it that way. Time to upgrade the plate maker to match the copier.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • bizhub1
      • Sep 2008
      • 230
      Thanks for the reply, that's kind of what I figured.
      • mrwho
        Major Asshole!
        • 4299
        They can always simulate it via Photoshop or Paintshop Pro - I use PSP and it has a filter that simulates the halftone - can't hurt to try.
        Mascan42
        Ibid
