Konica BizhubC353 wont print color with new 64 bit machine?
  • Lasman26
    • Mar 2010
    • 8
    I have hooked up a new computer and loaded the driver for bizhub c353 for Windows 64 bit.
    Customer can print in Black and white but not color . He was able to print in color with his old machine automatically.
    Is there anything else that needs to be done to be able to print in color ?
    2 others in same office can print in color but not new machine?
    Any insight would be much appreciated.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    where did you get the driver from ?
    I always download the drivers from the KM website.
    I dont recall but that model may have a minimum firmware level requirement for certain driver versions which may also be an issue.
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      On KM site is available a special driver called "mono color" that looks like the normal driver but in the quality tab the user can't select color mode, only B/W. My guess is that probably this is the driver in use on that pc. If not try using the universal driver. Last thing, I assume that the bh has only the standard controller and not a Fiery on the back..
      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
