Bizhub 1050 driver problem.
  • ReoNeo
    • Dec 2008
    • 25
    [Misc] Bizhub 1050 driver problem.
    Hello
    Hope that someone can help with a strange problem on a Bizhub 1050.
    The problem occure when you are printing from the driver. You get out the first set of print, and when you should print out the next set, the driver status said that you are out of paper.
    This happens for Pcl and Ps drivers. Happens on printing from Raw and Lpr print.
    The machine have the latest firmware, V70.
    Copy function for the machine is ok, no problem.
    There are no problem shown in display.
    Have tryed to reload software and init. nic settings.
    Thanks.....
  • Itsthepaper
    Supervisor
    • Dec 2007
    • 91
    1050 driver problem
    How does the message clear, opening the tray and closing or restarting job?? Does it happens on every job, and does it do it when copying?
    Love the Job Love the Work.
    • ReoNeo
      • Dec 2008
      • 25
      Hello and thanks.
      This issue happens only from the driver, no open, closing or resett on the machine. And the copy function is ok.
      When turn the machine on and of with the main switch. Is the printer ready in printer properties. And i can send 1 job, just after this job has been printed, will the under properties of the driver say no more paper.
      This happens from all programs and all files.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        make sure the driver version and the firmware version match or you will get strange things happening.
