Reset Developing Unit C220 ?
  • fornerm
    • 82
    Did anybody know, how ich can reset the Color Developing Units on C 220 Machine Series ?
  • JSC
    Gimp
    • Dec 2006
    • 618
    You will have to put a new one in, or if you google it im sure you can find someone that can supply you with a resetter.
    The gene pool could use a little chlorine.
    • perdana
      • Jan 2008
      • 62
      You can buy a new chip and put in developing unit.
      • fornerm
        • 82
        • JSC
          Gimp
          • Dec 2006
          • 618
          New firmware just out (C2) with it you can disable the end of life message!
          • perdana
            • Jan 2008
            • 62
            You can fin at Copier Chips Ltd | Suppliers of Imaging Unit Chips or katun.com
            • fornerm
              • 82
              Hi JSC,
              i know what you mean, i try it.
              I would prefer it if I could reset this
              and perdana,
              thanks for answer, but this is only for Imaging Units. Not for Developing Units.
              Apparently there is not yet.
              to all people,
              what do you do with machines whose developer units have expired?
              Buy new for 1000 € for 3 color units when the old ones are still good?
              thanks guys
              • Mr.Mel
                • Jul 2010
                • 9
                Copier Chips Ltd | Suppliers of Imaging Unit Chips Supply a dev interface and sims for resetting, why don't you use the latest firmware though? That's why it was released.
                • emujo
                  • Jun 2009
                  • 3009
                  I looked at the firmware Data base and I don't see any listing for C2 firmware (at least that deals with the replace IU message) for any of the new color (C360/C652) boxes. Where did you see this info? Emujo
                  • Mr.Mel
                    • Jul 2010
                    • 9
                    To: KONICA MINOLTA AUTHORISED TECHNICAL PERSONNEL
                    TECHNICAL SUPPORT GROUP
                    Date: 20 April 2011
                    Topic: bizhub C652 (DS5)5 2\C4\C52\C360\C280\C220
                    IU end of life message can be disabled
                    Description
                    With the new version of FW G00-C2 and above it is possible to disable the end of life
                    message for consumables.
                    This will enable the service technician to manage the replacement of consumables
                    based on customer needs and expectation of quality.
                    Considerations
                    If you decide to remove the end of life message then please be aware that
                    performance of consumables operating past the specified life is not guaranteed.
                    This Includes copy\print quality, paper jamming and any other issues caused by
                    extending the lifetimes.
                    Konica Minolta UK except no responsibility for any problems that occur when
                    extending consumable lifetimes past the Life Specification.
                    Notes
                    1) All setting advised in this bulletin must be made at the same time.
                    2) Even though the end of life message has been removed, when the specified life
                    value is reached the oil can warning icon will still appear.
                    3) The notifications on PSWC, Fiery Control Screen and CS Remote Care do not
                    change and end of life message is still apparent (MIB information is not changed).
                    How to apply end of life settings
                    1) Upgrade the FW to Version G00-C2 .
                    2) Make unit change setting.
                    Service Mode > System 2 > Unit Change > Set Service for Imaging Unit.
                    3) Select No Stop for each consumable.
                    For Imaging Unit\Drum Unit\Developing Unit.
                    Service Mode > Enhanced Security Mode > IU Life stop setting > set to “no stop”
                    For Transfer Belt and Fusing Unit
                    Service Mode > System 2 > Software Switch Setting.
                    Change Switch No: 55
                    Bit 2 _ ON (Transfer Belt Unit ‘no stop’)
                    Bit 3 _ ON (Fusing Unit ‘no stop’)
                    HEX should read ‘0C’ when both switches are set.
                    4) Eliminate Life Message Display.
                    Change Switch No: 51
                    Bits 4,5,6,7 _ ON
                    HEX should read ‘F0’ when all these switches are set.
                    Life Specification
                    Model
                    Drum
                    C\M\Y\BK Dev Unit C\M\Y Dev Unit BK Transfer Belt Fusing Unit
                    C220 9338 M 120000 counts 600000 counts 33033 M 550000 counts
                    C280 6244 M 120000 counts 600000 counts 22008 M 550000 counts
                    C360 6244 M 120000 counts 600000 counts 22008 M 550000 counts
                    Model IU C\M\Y Drum BK Dev Unit BK
                    Transfer
                    Belt Fusing Unit
                    C452 5180 M 10302 M 1200000 counts 320638 M 600000 counts
                    C552 5180 M 10302 M 1200000 counts 320638 M 600000 counts
                    C652
                    (DS) 5180 M 10302 M 1200000 counts 320638 M 600000 counts
                    Service Engineer Guide Lines when attending EM calls
                    • emujo
                      • Jun 2009
                      • 3009
                      Nothing on the US site for this. I checked with our support group and they say not released yet so I guess the UK is the guinea pig for this KMMOD. Emujo
                      • Mr.Mel
                        • Jul 2010
                        • 9
                        @ emujo - Do you have a G00 C2 firmware release at all?
                        • fornerm
                          • 82
                          Thanks for the informaiton. I will check it.
                          Very interesting.
                          • emujo
                            • Jun 2009
                            • 3009
                            Nope!. Emujo
                            • JSC
                              Gimp
                              • Dec 2006
                              • 618
                              Hi emujo
                              ths is the UK TAD number TNGB1100053EN00 not sure if this helps you or not!
                              I find it strange that its on the UK site and not the US...........................normally its the other way round
