Change the fusing unit
  • jokacross
    • 110
    The machine is asking for this part! there are a way to reset this message? thanks!
  • JSC
    Gimp
    • Dec 2006
    • 618
    And the model is?
    The gene pool could use a little chlorine.
    • jokacross
      • 110
      sorry. c450!!
      • JSC
        Gimp
        • Dec 2006
        • 618
        Originally posted by jokacross
        sorry. c450!!
        You can if you wish 'fuse it' when you open the side of the machine, there is a small brown cover on the left just above the fuser (one screw) you will see a connecter if you unplug it you will see within the wires of the conecter loom there will be a green 'pico' fuse rapped in heatsink. If you replace it that will reset the fuser unit.
        * WARNING *
        If your not sure on how to do this get a tech to do it for you, or order a new fuser unit.
        • jokacross
          • 110
          tell me please where I can get the fuse (site). I know how to change it. or say me the type of the fuse that I can search in the electronic store. thanks!
