NVRam Service/CE Code
  • Phill.Harden
    • Aug 2007
    • 27
    Hi everyone
    I have 3 low volume Di2510s which I have just discovered have a unique service password set.
    I cannot obtain this password from the wholesaler who supplied them.
    I am not directly connected to the local Konica Minolta distribution channel within Australia and can not obtain exchange nvram units.
    Phase2 service manual says if code is forgotten then PWB-A will have to be replaced.
    Is someone aware if the service code is retained in the 1K EEPROM IC3 plugged into PEB-A
    Without obvious options I am inclined to dump the memory in the ROM board and attempt to force a full initialise, but I don't know if this will lock up the machine.
    Possibly others have been in this same position and can offer advice or a pointer or two.
    Thanks... Phill
  • RRodgers
    • Jun 2009
    • 1947
    What I remember from school is if you forget the CE password yep you are going to have to replace the board. (or was it NVram?) uggg it's been years. I would think the code is held in the NVram. A full wipe might help but yeah, it can be a pain to reset the machine back up again. Course, if you change the NVram you are going to have to do that anyways.
    Good luck.
