Bizhub 250 - No Booklet Option
  • joneze
    • Aug 2007
    • 128
    Got a missing button on Bizhub 250 - Under aplication Book Copy/Repeat should be the option to do a booklet. On this machine however there is just a blank space, i have uodated firmware to and performed total clear to no avail. This seems to be the only thing missing everything else seems to be ok.
    Anyone had anything similar?
  • aleksander
    • 378
    have you ever tried to Total Clear?
    • joneze
      • Aug 2007
      • 128
      Yes i have tried, but still no booklet option
      • DocuSystems
        Service/IT/Integrator
        • Jan 2007
        • 54
        Are you able to duplex? I know that option becomes unavailable in the print driver if the duplexer is not set in the print driver options, perhaps it's the same from the control panel. There are soft switch settings to disable various options in the service mode if I am recalling this correctly.
