C-2454 Errroe on bizhub c6500
  • wld
    #31
    Re: C-2454 Errroe on bizhub c6500
    KM c6500 error code 2452(M) - I ran the fix suggested on i/o 54-03, but didn't stop it on time between 125-135... now it's wayyy low.
    How do I get the number back UP...
    now the code is 2422...
    Help - I have political mail to get printed and mailed today!
    Your replies appreciated!
    • SEnder
      • Jun 2008
      • 36
      #32
      Originally posted by texchar555
      hey guys this is how I fixed the issue . If you go to the I/O mode and type in 54-00 for yellow 2451
      03 formag 2452
      06 for cyan 2453
      09 for blk 2454
      run it untill it gets between 125-135 and stop exit out of mode and turn machine off.
      run toner refresh about 3x and your good to go.
      Big THANKS!
      I was cleaning cyan corotron and got this C-2453 after. After replacing corotron again, same fault. Done this procedure for cyan, and well done. Everything is back to normal.
      Cheers! and greetings
      Regards,
      SEnder
