C250 error c2152
  • danrobin54
    • Jun 2025
    [Error Code] C250 error c2152
    Can this error C2152 be cleared on the C250? or is sensor dirty? How would i clear if it can. Thanks
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      Transfer belt troubles I think. If you are not a tech, call one.
      • danrobin54
        Thanks. I am a tech. Sharp mostly. But have work on Konica Minoltas for about 4 years. just not these models. I did get the service manual. So I will read up on it.
        • RRodgers
          • Jun 2009
          • 1947
          On the newer Kinica boxes go into tech mode, then counters, then service call counter. The box will tell you what the code means. If its not listed in there, then its an accessory problem ( ie finisher, lcc, paper banks)
          HtH
          • remati
            • 149
            with this code ,you could have,
            the easy way...clean the sensor or change the transfer belt...
            ...or ...
            you could have the very difficult way...change the sensor and the actuactor...and for this you need some hours ....see tha manual how to do that ...
