Bizhub C450 won't print multiple sets
  • Metalvoc
    • Sep 2008
    • 155
    I have a customer with a C450 that will not print more than one set at a time. Does not seem to matter what program they are printing from, or how many copies of the document they request at the computer. Always prints only one set, and no errors. On the copy side, there is a message in the upper right corner that says "Memory 100%". Don't know if this is what it is supposed to say, or if that means the memory is bad.
    Is this a memory problem, print controller problem, or something else I'm not thinking of? thanks!
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Check the driver in use, and make sure that the driver is using the Fiery on a machine that does not have it, or otherwise. If you use MS Word, make sure they're not using the settings on the program instead of the driver, or are in conflict (eg check for sorting on both).
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      Most likely drivers.
      • emujo
        • Jun 2009
        • 3009
        Memory @100% is a good indication..when you see it start to drop down to 50% and less, then the MFP is working hard to process the job. Can you copy more then 1 set? Emujo
        • Metalvoc
          • Sep 2008
          • 155
          I did check to make sure that there was no problem with the setup. I have had enough problems with Word to know to check your settings first. They are printing from Works and PDF mostly. Didn't see any problems or conflicts with the settings, but I will definitely take a closer look at the driver itself. I mostly work with Kyocera, so I'm not terribly familiar with these models. Thanks for the great info!
          • kazimnaim
            Re: Bizhub C450 won't print multiple sets
            Hi
            I am facing the same issue i.e no multiple prints at all
            Can you advise what was the issue with you
            Regards
