How do I enable printing in a Konica 7155
  • Maindron1
    replied
    I used the one I had from my old copier and It is working fine now and I did not even have to reconfigure it since I am using the same computer to print to it.
    And by the way I had it against the wall blocking the cooling area (Guilty as one of the dunbasses), I had to pull it away from the wall. Thank you for adding the remark.
    Originally posted by Maindron1
    Hello,
    I just bought a copier Konica 7155 and I just find out that It is not set up for printing and I would like to set up the printing on it.
    How do I do it?
    Please help.
  • ddude
    replied
    If you you do not have a controller, I do have one available, complete with the attachment kit which is required. If your machine is equipped with a controller, there will be a bulge on the back cover, it will not be flat like discussed earlier.
    Just because you see a NIC port and a parallel port does not mean you can print on a Konica box, those ports were for servicing and firmware loading.
  • CT Copier Repair
    replied
    Originally posted by ct copier repair
    Many dumdasses Perth
    Many many dumbass customers
    had a lawyer with one in a closet
    couldn't open the front door oh were jams fun
    and he was surprised when it finally jammed
    told me to take it out
    i told him sure and when my back goes out I;ll sue
    so he told his secretary to do it
    she told him to F himself
    so he decided to do it and dropped it and it shattered his foot
    And I laughed my ass off
    many many dumbasses
    best part i forgot
    he wanted to sue me my company at the time and the manufacturer the manufacturer cooked his ass
    and he couldn't get a copier from anyone. No one would sell him one
    I sold him a typewriter IBM Selectric and charged him 100 an hour to service it 3 hour minimum
  • CT Copier Repair
    replied
    Originally posted by PerthKMTECH
    yep, you need the print controller, its a lump screwed on to the back of the machine in the upper most right hand corner.
    if your back panel is totally flat, no printing for you.
    Speaking of which, i wonder how many of these print controllers have been cooked by dumbasses having the machine pressed right up against a partition panel sealing its cooling vents. I've certainly seen a few die that way in my time.
    many many dumbasses
  • EarthKmTech
    replied
  • remati
    replied
    ...IP 511...If I think.....
  • Pier
    replied
    Have you bought IP controller also?, It was option. The password to configure the nic is sysadm.
    good job
  • Maindron1
    started a topic How do I enable printing in a Konica 7155
    Hello,
    How do I do it?
    Please help.
