C2211,2212,2213 codes intermittently
  • WayneT
    • Mar 2025
    [Error Code] C2211,2212,2213 codes intermittently
    i am getting these codes at random (drum speed). customer is running medium weight paper. Knowledge base recomends adjust drum speeds which I have done. I also re-powdered all drums which allowed about 2k clicks before coding again. any ideas would be greatly appreciated.
    Wayne
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    I would pull out the drum carriage and clean the connector on the back of the machine and drum carriage. I have seen many codes caused be that. Also, you might have a bad set of drums. Did this start after replacing the drums? If so I would swap them out.
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
