Error code J32-02
  • Maindron1
    • Mar 2011
    • 38
    Error code J32-02
    I need help with a J32-02 from a Konica 7155. I have done everything and it still doing it. Any inout will be greatly appreciated.
    Thank you.
  • minimerlin
    • 851
    What exactly have you done to try to clear it? Are you a tech? Do you have the manuals and have you followed the troubleshooter? Have you used the search on this forum for this code?
    Please do not PM me without asking first.
    • Maindron1
      • Mar 2011
      • 38
      I switched the fusing unit with a working one, I changed the ADU board. One thing I notice is that the solenoid switch that opens up the exit gate does not come on, the paper stops while going down the duplex and that is why I thought that the ADU board was faulty. Yes I have the 2009 updated manual for this machine and I have followed the troubleshooting steps and it is still doing it.
      • minimerlin
        • 851
        Does the fault happen when doing copies from the glass and via the Doc feeder? What about the internal test prints.
        • Maindron1
          • Mar 2011
          • 38
          It does it for everything even face up copies.
          • minimerlin
            • 851
            A face up copy does not go into the turn around area so you need to find out why it is! Is the return spring fitted to the guide?
            • JustManuals
              • Jan 2006
              • 9838
              Just Manuals | The Internet's largest selection of manuals | Instant Downloads
              Paul@justmanuals.com
