minolta 1054
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    minolta 1054
    Hello
    I change the drum and now i have very light copies.No changes if i playing with
    F3 or F5 settings.What the hell can be wrong.I'm not familiar with Minolta.
    Can anyone give me a tip.
    Thanks.
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    BEST TECHNICIAN . NICE PEOPLE .
    • Gaffers01
      • May 2011
      • 335
      Hi,
      I havent worked on this machine for a while but i think you have to run F8 when you replace the drum then F3 and the F5 in that order. If this doesnt work go in to F5 and you can manually adjust to make the copies darker by pressing the up or down key.
      • ck1
        • 485
        at F5 section use up & down button to manual adjust the value then press start button
        • JustManuals
          • Jan 2006
          • 9838
          Send me an email. I'll send you the SM.
          Paul
          • bojans
            • 1313
            Long time I didn't work with these models.
            Use to have problems with light copies caused with transfer corona assy. Try to find another one and change it. You can also play with lamp settings.
            We use to set up everything with these settings:MINOLTA 1054 dijagnostika.pdf
            Good luck
            • zoraldinho
              • Mar 2008
              • 5018
              Thanks for the posts.Will be in touch.
