konica bizhub c300 network problems:
  • ybnews
    • Oct 2008
    • 94
    I just got a used Konica Bizhub c300 with no paperwork.
    I want to network to my computer.
    I need to change the IP address
    How do I bypass the Admin password?
    Thanks,
    Dana Lewis
  • RRodgers
    • Jun 2009
    • 1947
    Thanks,
    Dana Lewis
    C300? Is there a C300? Don't think I've seen one. You don't bypass the admin password you put it in. If it IS a C. (Color box) try the default. 12345678 (in the manual and the manual is on KM's web site) if its a Black and White machine use the default (00000000 eight zero's) if that doesn't work, call me and I'll give ya a good rate on making it work.
    • aesthetics1
      • May 2010
      • 148
      A Bizhub C300 has a fiery controller most likely. You should see a little device with a power button towards the bottom on the back of the machine. This is the device you need to get into and configure. You can typically get into it by going into Utility > Controller Details, and going into the setup from there.
      Good luck
      • RRodgers
        • Jun 2009
        • 1947
        I just looked on KM's web site... wow... there is a C300. I don't think I've ever seen one. (not that they would probably look much different from any other KM box)
        • JustManuals
          • Jan 2006
          • 9838
          I've got all the manuals for the C300
          • ineo+6501
            • Mar 2010
            • 262
            The C300 is a 30 page per min version of the C352. It is identical, same units & toners etc.
