I need service mode procedure to get into service mode-------also need service code to use after installing drum and blade----thanks in advance-----------John
konica 7145
7145 drum/blade info
To reset drum counter go to 47 mode address 91 press 1 press print
Then go to 25 mode parts counter fixed parts scroll down to drum then reset then to blade and reset
The parts counter has no effect on the copies it is only a counter for your referance whereas the 47 91 resets the drum compensation data
hope this helps
merry xmas
bushy
