Colorforce 8050 No Scanner/Printer Function
  • Beachguy
    • Dec 2007
    • 26
    We've got a strange one with a Colorforce 8050. The machine is only working a copier right now. The buttons that select the Scanner or Printer function do not even light up. There was a power outage over the weekend so maybe something popped. The controller board does have green and red LEDs working though. Thanks for any help.
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    What type of controller is on the machine?
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • random
      Sounds like a IP-921 if you have have flashing LED's. There are four LED's arranged in a square shape that are used for diagnosis which ones are lit up?
      • Livebychance
        • Dec 2007
        • 34
        Hard drive failure?
        • Beachguy
          • Dec 2007
          • 26
          The controller is an IP-921 and there were two geen LED'S: one flashing and one solid. There were also red LED'S and they all appeared to be on. I'm going by memory here so I'll confirm that when I'm at the machine the next time.
          • random
            When that IP is booted up normally all LED's should be off. If they are all on there is a problem with the controller.
            • Beachguy
              • Dec 2007
              • 26
              O.K. here's the latest we've found so far. Of the four red LED's arranged in a square, two are on: the top left and the bottom right. There is a green LED right below that which is on all the time. Where the network cable plugs in there is one solid green light and one flashing green light, however the printer is not recognized on the network, in fact in can't be pinged. There is another ethernet connection to the left (for diags?), which CAN be pinged. As stated before the controller is an IP-921 and it has an HDD-106. My guess is because the machine acts as only a stand-alone copier this is the reason it can't be recognized on the network. Thanks
              • Livebychance
                • Dec 2007
                • 34
                Hard drive is bad. on fiery.
