C252 - Copies ok prints dark
  • joneze
    • Aug 2007
    • 128
    Hi all,
    Got an issue on c252 that when prints are produced they come out really dark to the extend that reds come out a more brown colour then red. If you are to do the same as a copy the reds are OK.
    Driver installed is the lastest PS driver no driver brightness settings...etc have been adjusted, firmware is all up to date on the machine.
    Any suggestions will be appriciated
  • rangertech
    • Jun 2011
    • 40
    Hi.. Joneze
    you can trying to print with pcl printer driver.
    • ddude
      General Troublemaker
      • 473
      Have you calibrated color for 'print'?
      2000 mockingbirds = 2 kilomockingbirds
      • SPBE
        • Sep 2010
        • 70
        I had the same problem with one a while back and had to load a special firmware.
        • ck1
          • 485
          what special f/ware you use ?
          • SPBE
            • Sep 2010
            • 70
            I cant remember, it was so long ago. I tried to find it this morning, but so far no luck. I'll keep looking and let you know.
