bizhub 421 "touch & print" box problem
  • ineo+6501
    • Mar 2010
    • 262
    Hi Guys,
    Got a problem with 5 x bizhub 421's at the same customer. All 5 machines have the same issue.
    All are configured the same: bizhub 421, HDD, IC module, AU-101 biometric.
    Set up with biometric based user authentication with each user tied to a department in account track. Touch & Print is switched on so the print jobs will be held until the user puts a finger on the bio unit.
    Now the system works really well except for 1 problem: When the user asks for more than 1 in the print quantity, the machine will only ever print 1. When I turn off touch and print so the machine will immediately print the job, it will print multiples. I have been through all of the user and sdmin settings and cant see anything wrong.
    Copy mode works perfectly.
    Any ideas?
  • dallas
    • Jun 2008
    • 115
    Maybe this setting works ...
    • ineo+6501
      • Mar 2010
      • 262
      Your the man Dallas, that was the problem. Changed the sw setting and all is now working.
      I owe you a beer
