Have you had this sort of noise from machine?
  • habik
    • 2013
    Re: Have you had this sort of noise from machine?
    Originally posted by habik
    OK.
    My ghosting problem came back again.
    Cleaned spotlessly everything on 2nd transfer side and it went away for 2 weeks. Now it came back again. Cleaned everything again as before and I was not so lucky this time. Problem still persists. It does not appear however on A4 R (A4 landscape) have not tried A3 yet...
    see scans below:[ATTACH]13523[/ATTACH]
    OKAY
    1st and 2nd Transfer adjustments did the trick!
    Done 3x500 sheets and with only little very minimum streaking hardly to see it works fine!
    Firmwares HERE
    • minimerlin
      • 851
      Just looked at the Test Print ...has the extra mylar sheet been added to the transfer roller area? It is designed for just that fault, without adjustment of transfer voltages.
      Please do not PM me without asking first.
      • habik
        • 2013
        Well ..I had a 2nd transfer unit in place that already had the mylar strip and it was still doing it. I could not figure out what is causing it despite playing with the settings, I decided to change the whole 2nd transfer assembly and the one I put in did not have the mylar strip and it worked. however eventually it came back... until I fluffed around with the settings to get the best results.
        It has been running for 2 days now and it seems like its OK..hope I haven't jinxed it
        Firmwares HERE
        • eg101
          • Jan 2005
          • 131
          #19
          I would check fans . A piece of trash could be vibrating against one of them.
          Or a foam filter got sucked into a fan.
