Konica 7155 no error code when jam occur
  • Maindron1
    • Mar 2011
    • 38
    When I was operating my first Konica 7155, there was always an error code when a jam occur which always make it easy for me to locate the problem. I just bought a used one (still 7155) with about 400,000 copies on it does not give me an error code when a jam occur. What can I do to fix that.
    Please, any help will be gratefully appreciated.
    Thank you.
  • CraigW
    • Dec 2010
    • 417
    In 25 mode, set switch #11 bit #7 to a 1 to display jam code.
    • Maindron1
      • Mar 2011
      • 38
      Does that mean that when I am in mode 25 I select "Software SW Setting" and the first number is the switch which I go up to 11 and the second number is the bit which I go up to 7 and from there I highlight ON(1)
      Just did it and It is working now. Thank you so very much.
