HELLLLLLLLP
Going to put it out there that this is the first 552 I have been on.
Il set the story. Customer bought this machine new back in '09, not from us. Owner switched hands so the machine sat idol for about a year. Flash forward to April. Guy wants us to service it. I go down see that the machine has 19xxx copies and say its a decent platform. Well in my course of doing a basic cleaning I run the machine and it starts throwing codes. First code was a C-2558, high (K) toner density. After running it a bit more it popped a C-B003 Fax error. Couldn't do anything with the fax error so I just disabled it. But now I am stuck with the C-2558 error. Before I was at least able to make a few copies before having to reset the front door for the code. I spoke with our rep and he mentioned the IU. Finally got the unit in and swapped it. Still throws the code on start up. I adjusted the TCR level as the hotline mentioned. And now I am just stuck. Any help would be greatly appreciated.
I have read several responses on here stating they swapped the unit but I have already done that. GEWWWWWWWWW
