Bizhub 25 Admin Password - Web Connection
  • Marlene Miller
    #16
    Re: Bizhub 25 Admin Password - Web Connection
    By default there is no set password for Administrator, you create one by going to the MFP panel and press [settings] then [Management] then [Admin Password] then create a password of your choosing and then [ENTER] Enter password again and then [ENTER].
    • Computerspacelv
      #17
      Hi Everyone,
      If you forgot your password, simply turn of the printer, turn it back on and follow:
      1- Turn Off the printer
      2- Turn it back on
      3- Click on setting
      4- type *24
      5- You get 2 menu to initilize and other one which i fogot, simply press both and follow the screen, with this you reseting the password.
      you can do a factory reset by going to setting > management.
      Best.
      • peter42
        • Jan 2012
        • 110
        #18
        Dont forget, after 3 choices of login, you have to restart the mfp.
        If you enter correct password after the 3th one , nothings happens, no failure meassage appears and you have no access, until restart.
