Bizhub c550 has white lines
  • Goodluck
    [Misc] Bizhub c550 has white lines
    Having white line acorss the page, and print the test pattern page.Only Black has white line, So i change the drum and the transfer belt, still got the same problem, dont know what else to do. please help
    Thank you
  • minimerlin
    • 851
    Call a TECH?
    Please do not PM me without asking first.
    • mrwho
      Major Asshole!
      • 4299
      If you've got white lines only in black and you replaced the transfer belt, then you've probably spent money on unneeded parts - so Minimerlin is right, you should call a tech. It would probably be cheaper already!
      Nevertheless, if you changed drum and the white lines persist, you could have dirt on your laser optics - can you post a scan of the defect?
      Mascan42
      Ibid
      • CT Copier Repair
        • Mar 2010
        • 304
        Call a tech
        color is not 4 times harder
        its many many times harder
        and not end user friendly
        or spend more money and replace the developer and charge coronna and the gizmotron and the whosiwhatsit
        • RRodgers
          • Jun 2009
          • 1947
          Originally posted by ct copier repair
          Call a tech
          somehow, I feel a tad bit responsible for this post. hahahaha
          • seeb
            • Nov 2009
            • 41
            Probably lint in the laser path. Pull out the developer units and clean the underside of them and the cavity they reside in.
            • Gaffers01
              • May 2011
              • 335
              Its toner of residue on the LED unit under the blk iu, there's a long piece of plastic in the top paper tray under a flap use that to wipe the LED. If this wont clean it you need to clean it with some white spirit by taking out the image unit and transfer belt you can then get to the LED assy easily.
