Bizhub501 fax forward
  • KM7155
    • Aug 2008
    • 146
    Hi mates,
    can the bizhub501 forward the incoming fax to a destination in one-touch setting?
    the bizhub250 can be done, but i can't find the setting in this model, since this model
    is using konica firmware instead of minolta firmware like the b250.
    hdd is not an option in this case.
  • emujo
    • Jun 2009
    • 3009
    Yes, Admin..FAX setting..TX forward settings...once you turn on fax forward, you should see the address book icon, touch it and select your destination. If you don't see this double check the fax is electronically installed, US marketing..and if still nothing, reload firmware. Emujo
    • KM7155
      • Aug 2008
      • 146
      thanks for the info, the issue settled.
