Cf2002 fusing unit reset
  • ingridmv
    • May 2025
    is there a way to re-set the fusing unit on a Cf2002 without purhasing a new one??
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    There is a 50mA fuse (with wires) hiding up inside the fuser. Be careful, things are quite fragile (lamps and such).
    If you are hitting your head up against a wall it always feels better when you stop.
    • bigpa
      Thanks for the advice but I can not find the fuse, you would not have a scheme?
      PS excuse my English machine translation from Italian on google
      • danito0203
        reset cf2002 fusing unit
        hello.
        did you find the way for reset cf2002 fusing unit?
        need help also, can't find the fuser.
        txs a lot
        • bowser
          • 25
          2002fuse
          the fuse is a 1/16amp pico fuse and is behined the connector
          remove the back panel of fuser be careful it is a loop back wire covered with heat shrik rubber tubing in the connector
          • charlie eglinton
            Parts No. for the fuse
            Hi:
            1.Where can I get the fuse, RadioShack? Or from Konica-Minolta.What is the parts # then?
            2.Could you also clarify/ confirm 1/16amp pico fuse and not the 50mA fuse as mentioned by another member?
            Thanks.
            • bowser
              • 25
              fuse
              yes a 1/16 amp fuse ill get part #
              • charlie eglinton
                cf2002 fusing unit reset
                Still waiting for the parts No. As it should be cheaper than buying a fuser reset module that allows you to reset the Fusing Unit instead of replacing it.The cost of the unit is $75.00 and only requires a new 200 mamp fuse ($1.00/each) each time you reset a fusing unit.(info obtained from the following site:Copy Life - Your supplier for IU boards for color copiers )
                Any experience/feedback with this reset module,please share. We have both CF2002 and KM 8020 in this office.Thanks.
