konica 7150 can't acces mode25
  • iori30
    hi all,
    I have the F51-1 code on my copier. I've check the fuser lamps, one was not in contact. I've cleaned fuser, temperature sensor.
    When i've tryed to go to mode25 to reset dipSw, the copier want a code (4digit). I don't have this code. I've try 0000, the sn of the copier... not working.
    I think that i have to make a "clear all", but i don't know konica's copier. And i don't have the values of the adjustement that i have to reset.
    Someone know a way to help me ?
    sorry for my english, i live in france
    thanks for help
    iori
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1076
    The code is a developer speed abnormality, just find what is causing binding, once the problem is resolved no resset is needed
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • iori30
      i've make a mistake, the code was F35-1
      • pepper38_cnd
        • Aug 2005
        • 1076
        There should not be a password to get into 25 mode just hold 2&5 while powering up machine, if it insist on a password try 9272 standard service password.
        • iori30
          it works. thanks a lot
