How to Print banner via C450
  • akbareshghi
    • Sep 2010
    • 261
    [Misc] How to Print banner via C450
    How to print banner via 450 konica minolta ?
    please explain the way(the paper and print setting ) of it ?
    thank you very much
    Color printing with lowest cost per page is my love.
  • JustManuals
    • Jan 2006
    • 9838
    RTFM
    • akbareshghi
      • Sep 2010
      • 261
      i know but my mind is how to setting the paper of Banner in drawer1 please
      please explain more information about banner printing
      thanks
      • jhbtech
        • Oct 2010
        • 14
        banner mode should be activated in the user mode settings and then paper should be loaded in the bypass tray and size should also be set.
        • akbareshghi
          • Sep 2010
          • 261
          thank for your reply
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            Firstly, you cannot run banners through tray 1, only through the bypass.
            Secondly, you must detach the finishing unit from the machine. You don't need to unplug it, but it must be seperated from the main unit.
            Next, you cannot set the banner paper size on the machine due to the size limitations of the device in it's normal mode.
            When you press the utility button, you will see an option for banner printing. Select it and then select ON. The machine will go into banner mode. You cannot change any settings or do anything else with the machine while in this mode. Any other print jobs will hold until the machine goes back into normal mode.
            Next, set up your print job and be sure to specify Custom paper size in the dimensions of the banner paper you are using.
            Submit your print job. The machine will prompt you to load XxY size paper in the bypass tray. Load your banner paper, and the machine should pick it up and print the job.
            You may need to change your dimensions in the driver around. (i.e. 40x11.5 as opposed to 11.5x40) I cannot remember for sure which way the dimensions go. Also, make sure the document you are printing is of the same dimensions, or you set the reduce/enlargement function accordingly.
            • akbareshghi
              • Sep 2010
              • 261
              thanks very much for comprehensive answer
              • empiru
                • Feb 2011
                • 229
                Hi!
                I just want to tell you a little, but important detail: don't put the paper in the bypass tray until the job is submitted by the machine. First time I printed a banner on C450, it took me almost an hour to figure out why the machine wasn't printing - because i set the paper in the bypass tray before the job "got" to the machine.
                Good luck!
                I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
                • kronical
                  Kronic Copier Ninja
                  • Nov 2009
                  • 230
                  Originally posted by empiru
                  Hi!
                  Good luck!
                  Yes I have run into this every time as well. However, in the instances where I have loaded the paper before the job was processed, all that happens is it will prompt you to load the specified size paper into the bypass tray. Pulling the paper out, waiting 5 seconds, and reloading will get it to go. (Or should)
                  • habik
                    • 2013
                    Re: How to Print banner via C450
                    If you print from Publisher I suggest you print it as published pdf. Easier Especially if you print several copies.
                    Firmwares HERE
