2 questions.
#1 how do you separate the sorter(donot know model # of sorter) from copier to clear/look-for misfeed. I move release lever and top moves away as much as possible but held up at bottom not sure what??? Thanks!!!
#2 m/c corona wire dusting up due to seal on dev. unit cover away from drum. I notice if light pressure is applied to cover seal closes gap. would problem be with seal or what appears to me to be warpage in cover??? Thanks!!!
