Torque limiter
  • beweak
    [Misc] Torque limiter
    it was my first time to post here,
    I would like to ask regarding the C6500/C6501, about the TORQUE LIMITER under the FUSING UNIT, what is the use/purpose of this limiter........can any one share some ideas regarding this.............
    Thank you ..........
  • habik
    • 2013
    Have no experience with C6500 or so but Torque Limiters are used to eliminate any unnecessary movement or slow down by using either magnetic or friction element. It is widely used on separation rollers under feed tyres (separation Tyre).
    I would imagine that it is there to slow the rollers of not over slipping forward if oneway bearing is used, but I might be wrong as this is just from my head haven't seen any manuals yet
    Good Luck
    Firmwares HERE
    • empiru
      • Feb 2011
      • 229
      Habik,
      You said you are not sure about what you are saying - well let me tell you, you are 100% right
      Beweak, all the information you want was just given to you by Habik.
      I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
      • beweak
        Re: Torque limiter
        Thank you so much HABIK................
        • mr_drucken
          Re: Torque limiter
          torque limiter used for timing,.when the fusing belt engange and release..mr_drucken
          • charginga
            Re: Torque limiter
            Torque limiter very important for fusing work,so many things that will be caused as very long warming up.
            • JustManuals
              • Jan 2006
              • 9838
              Re: Torque limiter
              I only have experience with these on HP printers, but what happens is, that from rubbing against the magnet, the limiter builds up with magnetic shavings inside the limiter and once in a while you have to take it apart and take out about 50% of the shavings. Then re-assemble it. This little tidbit of information is not listed in any HP service manual.
              HtH
              Paul@justmanuals.com
