Bizhub c6500
  • newbie12
    • Jun 2025
    Bizhub c6500
    Does anyone know if it's possible to print a brochure using 2 colors (PMS and black) to print the black/grayscale in true black or grayscale? The grayscale parts of the project prints with a slight tint of magenta.. sometimes it prints with a yellow tint and sometimes, blue.... any ideas on how I can get rid of the tints and still print the PMS color as how it's suppose to look? Thank you in advance!
  • JDZ
    Re: Bizhub c6500
    Hi and welcome to the forum
    - Is the project in PDF format? If so and you have the Pitstop plugin for Acrobat, open the file, change the tint values of the problem areas from CMYK (or RGB) to greyscale only and resend the file to the RIP. If you try and print the whole file as greyscale using Print Manager, it'll obviously make the PMS greyscale as well.
    Hope that helps??
    Cheers
    • newbie12
      Re: Bizhub c6500
      Hi JDZ
      Thank you for your respsonse... I don't have the Pitstop plugin but will look into it... and follow your suggestion...
