fk-503 installation problem
  • sifattttt
    • Mar 2011
    • 10
    need help,just install the fk-503 on bizhub 350 machine,when try out,the fax won't dial and keep error E5DF57(E-MAIL), any step i missed out?
  • aleksander
    • 378
    Re: fk-503 installation problem
    set G3 fax as a default. You can change it in Admin 1 - TX Setting - Quality/Mode - Communication mode, then change it to G3 fax.
    • JR2ALTA
      • Feb 2010
      • 2031
      Konica's are not intuitive (smart) they are built for and by engineers. Make sure you have the installation guide to be aware of each hoop you need to jump through.
      • sifattttt
        • Mar 2011
        • 10
        thanks Aleksander and Jr2alta,i found the error,it's because of set to G3 settings dat what Alek said.
