C-2555
  • phocop
    • Jun 2025
    [Error Code] C-2555
    Customer has fitted new yellow IU to fix this error. Worked ok for a week then error returned. Have reset but error keeps coming back. Any suggestions?
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: C-2555
    1st thing to check is the toner btl, make sure that there is toner in it & the "trap door" is opening correctly and alowing toner through to the IU.
    The gene pool could use a little chlorine.
    • sprawl
      • Jul 2009
      • 27
      Re: C-2555
      There is yellow toner "tape" jamming, so the IU do not have any toner.
      [Completed] Outaward, [Completed sertifications] C652,C552,C360,C280,C220,C35,C353,C203,C20p,C25
      • phocop
        Re: C-2555
        Thanks for your replies.
        Found tape obstructing toner from yellow toner cartridge.
        Problem solved
