Konica Minolta Bizhub 600 code Error invalid Font
  • bozzneil
    • Aug 2025
    can anyone encountered this error for bh 600? Error Invalid Font
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica Minolta Bizhub 600 code Error invalid Font
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • MILLER4157
      • Feb 2011
      • 48
      If you are using the font management utility, make sure that you are using a valid font.
      I would try updating your firmware before you mess with adding and removing fonts from the machine.
      • 940021
        It's pc font mismatch machine's font...!!
        try this one...
        printer driver -> Printing Preferences -> Quality -> Font Setting -> Download Font Format (Choose Bitmap) & Don't Use Printer Font
        then Apply those setting...
        p.s. Sorry for poor english....
        • MILLER4157
          • Feb 2011
          • 48
          I'm guessing the issue is with PDFs. Try an nvram and HDD reset. Check to see if your additional memory is also picked up. If not replace the memory
