Minolta 5000
  • hassan123
    • Nov 2009
    • 19
    Minolta 5000
    Hello Every Body
    The Old minolta 5000 create a problem for me.
    After a single copy made. machine goes to please wait.
    when i restart the machine the status is similar.
    Toner tank full with toner (NO NEED FOR MORE TONER)
    I dont no what wrong with machine. Have any soloution??
    I am waiting........
  • JustManuals
    • Jan 2006
    • 9838
    Re: Minolta 5000
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
    Paul@justmanuals.com
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      Re: Minolta 5000
      hello friend maybe you check bad similar toner ..maybe the motor how moving the toner down is bloked ..well if the service manual is usefully sent me your mail l have for minolta ep4000 l think it is same model
      Originally posted by hassan123
      Hello Every Body
      BEST TECHNICIAN . NICE PEOPLE .
      • Cantechman
        • Nov 2008
        • 228
        Re: Minolta 5000
        Is the machine making any noise while in the please wait mode? If it is making a motor noise it may be still adding toner and you may have a bad ATDC sensor. Also if it has a sorter attached, remove it and try again. That gave me that problem once years ago. If you go into tech mode you can check the toner percentage level, it should be around 6% I believe.
        • tonerspot
          • Nov 2008
          • 79
          Re: Minolta 5000
          replace drum
          • hassan123
            • Nov 2009
            • 19
            Re: Minolta 5000
            HELLO FRIEND
            my email addres is shah_naseem4u@yahoo.com
            please send manual i am waiting.
            thanks again dude
            • Cantechman
              • Nov 2008
              • 228
              Re: Minolta 5000
              Originally posted by tonerspot
              replace drum
              That wll do nothing to fix that problem
