J-3204 error when running 6.5x9 cardstock out of tray 5
  • qualityprintersllc
    • Aug 2025
    [Jamming] J-3204 error when running 6.5x9 cardstock out of tray 5
    As the title says, I was trying to run #100 card stock face up out of tray 5. Without fail it jammed every sheet and spat out the J-3204 error code; opening the indicated part to remove the jam revealed the sheet to be askew between the rollers, as though it was too small for the machine to feed it through in a straight line. I tried printing in both short and long position, and bending the paper a bit to see if that would help it get past the rollers. No dice. I ended up having to run it through the bypass tray of our C500, which worked fine.
    Any ideas what could be causing this? As the sheet size wasn't too small for what the machine is capable of, I'm curious why it wasn't able to feed it correctly.
  • Darren King
    copiertech
    • 652
    Re: J-3204 error when running 6.5x9 cardstock out of tray 5
    Hard to give advice without the model of copier, however, usually it is tray one and the bypass that are designed to handle thick paper.
    Hope this helps
    Darren
      Woops, sorry! It's a KM C6500.
      • Ianizer
        • Jul 2011
        • 380
        Qualityprinters,
        Setting
        Troubleshooting
        Deprive the bypass of paper. Send your job.
        The out-of-paper print alert is your friend. It will tell you, to a degree, what's wrong.
        Stop. Read
        My name Peggy.
        You got problem?
          The stock was a client supplied cardstock, so we didn't have the exact specs on it. It felt about the same as #100 cougar, so I ran it face up on the heaviest gm2 weight in tray 5 just to be safe. It wasn't coated.
          Our 6500 doesn't have a bypass. When I ran it out of tray 5 I never received an out of paper error; the problem arose after it had already printed and was making a second loop through the fuser unit. I'm not sure what the exact point in the machine is called, but it corresponds to knob M5. When it reached that point the paper skewed and it threw out the J-3204 error. I had to remove the paper from that point and open and close the door on the finishing unit (the door directly to the left of the section with the fuser unit) to clear the error.
          • Ianizer
            • Jul 2011
            • 380
            Hm... Just thinking out load here...
            Paper setting seems fine. Let's rule it out as a possible problem, mkoy?...
            3204 jam... PS17 isn't turning off.
            Post-jam skew. Suggests a physical obstruction. Whether debris or guide/roller problem... Maybe catch jam where it skews and really dig in with a light and probe, disturbing the jammed sheet as little as possible.
            This sounds like a mechanical jamming issue. The skew suggests everything is doing its job but the paper is hanging. Where? Why?
            I submit that J-3204 is a mere symptom. PS17 is doing its job famously. You got a bogy.
            Please post results.
            -I
            My name Peggy.
            You got problem?
            • lucky13
              • May 2008
              • 125
              Originally posted by qualityprintersllc
              The stock was a client supplied cardstock, so we didn't have the exact specs on it. It felt about the same as #100 cougar, so I ran it face up on the heaviest gm<SUP>2</SUP> weight in tray 5 just to be safe. It wasn't coated.<BR><BR>Our 6500 doesn't have a bypass. When I ran it out of tray 5 I never received an out of paper error; "the problem arose after it had already printed and was making a second loop through the fuser unit". I'm not sure what the exact point in the machine is called, but it corresponds to knob M5. When it reached that point the paper skewed and it threw out the J-3204 error. I had to remove the paper from that point and open and close the door on the finishing unit (the door directly to the left of the section with the fuser unit) to clear the error.
              2nd loop through the fuser ? were you trying to duplex this stock
              • Ianizer
                • Jul 2011
                • 380
                That struck me to... Must have gotten distracted... Or printing face down... -I
                My name Peggy.
                You got problem?
