minolta di3510 drum reset
  • slybot
    • Sep 2010
    • 165
    [Misc] minolta di3510 drum reset
    hi all
    does anyone out there know how to reset the drum counter on the above machine. customer has one the has been showing 'replace drum cartridge' for the last couple of months. been trying to get the stuff from KM, and having very very limited success. or even the part number of the drum unit would be a nice help too. thanx heaps
  • JustManuals
    • Jan 2006
    • 9838
    Re: minolta di3510 drum reset
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • boanda
      • Feb 2011
      • 79
      4515-711 DEVELOPING UNIT,
      Read manual FIRST! u must delete earlier value of developer from SM mode, othervise machine "can" go crazy
      • slybot
        • Sep 2010
        • 165
        hi boanda
        4515-711 is the dev unit, which i ordered from KM (under advisement from them) which is not what i want. found the part number of the drum unit and have ordered. having said that i got 1 pack (small) of dev with it that i ordered. looking at it i would think that it needs more than one pack of dev for the dev unit, would i be correct in thinking this. also we haven't got the manual for this machine. we sold it just before we stopped being minolta dealers and hence never got one
        • ineo+6501
          • Mar 2010
          • 262
          The 3510 has a very small dev, I thinks it's the same as the bizhub 210 dev (but don't quote me on that.
          Suprising how small the bag is.
          As for the drum, if I remember correctly there is a fuse in the drum unit on that model.
          They are a pain in the neck. Good luck
          • slybot
            • Sep 2010
            • 165
            looking at the dev unit; it must be a dr who dev unit. and i vaguely remember the fuse thing. (got torn a new one from my boss years ago when i revamped a drum unit with dev drum and fuse and it cost more than just ordering the unit)
            • Darren King
              copiertech
              • 652
              There is NO fuse on the Di3510. Just clear counters and run F8
              Hope this helps
              Darren
              • WildbillC
                • Oct 2010
                • 49
                4515-612 is the # for the drum, reset the counter in the service mode with the right side door open. The counter won't reset if you don't.
                Its always better if you have the manual with you.
                • remati
                  • 149
                  reset the drum count in the service mode...
                  ... but, better for you is change the drum and the developer and run the F8
                  ..if you reset the drum and run the F8 ,without change the developer,you can have a mighty headache
                  Originally posted by slybot
                  hi all
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4713
                    If you go into "soft switch settings" and put it in mode "418" and then change the #3 bit in the string to "0", then reboot the machine, the message will go away.
                    • boanda
                      • Feb 2011
                      • 79
                      hi boanda
                      Use DV110( for di152, bizhub 162,163) an tn114 for that machine. Dv 110 weight is 200gr.
                      Im using those and all works fine!
                      ...and as I said,DELETE earlier value of developer and drum before u do F8!
                      • jonmeen
                        clear maintenance counters and Important clear Special parts counters PC Lite L/C Life clear
                        • slybot
                          • Sep 2010
                          • 165
                          WOOHOO finally got the drum unit last week. took long enough. thanks for the replies. much appreciated. with the value of dev and drum, i'm taking a stab in the dark that it is a soft switch. which one and what bits do i have to reset. sorry to be a pain. and again thanks everyone
                          • Darren King
                            copiertech
                            • 652
                            Just clear the PC drum counter in service mode under counters-special parts counter. Then run F8 in service mode under function. (takes 3 or 4 min) and that's it.
                            Hope this helps
                            Darren
                            • slybot
                              • Sep 2010
                              • 165
                              hi everyone
                              got it all sorted out (i think). machine has been replaced now anyway. thanks for all the replies and help. much appreciated
