Minolta C350 with intermittant C0096 and noise from right door.
  • wingit
    • Feb 2011
    • 84
    [Error Code] Minolta C350 with intermittant C0096 and noise from right door.
    Can someone shed some light on Minolta Bizhub C350 with code of C0096.
    The code happened Wedsday went-out Thursday cleared code, they called back Friday with code came back after less than 100 copies. I pulled all drums out and T-belt (spins freely) Transport belt is less than 6 months old,customer is low volume (4K month) manual says Image Transfer Belt pressure/retraction failure. Has a loud noise only when turning on copier, Copies look good, color and black/white.Noise coming from right-side door M7 underneath the transfer roller. I lubricated the the gears driven by M7 and the noise is less. Could the 2nd Image Tranfer pressure/retraction Moter M7 be putting to much stress on transport -belt causing code? Should I order M7?
    Any help is always welcome. Machine has less than 250k.
    Thank-you Sef
    Give a man a fish he eats for a day,Teach a man to fish he eats for a Life time.
  • empiru
    • Feb 2011
    • 229
    Re: Minolta C350 with intermittant C0096 and noise from right door.
    Hi! I don't know what to say about that noise (are you sure it's not coming from the fixing unit?).. About the C0096 code, I can tell you, it clears temporarly if you open and close the front door (the one from the toner bottles) - so, if your customer has a little patience, he can use the machine in this way for a couple of days... I had the same code in a Minolta CF3102 (it's exactly the same code, meaning the same thing, belt retraction...etc) and first, I tried to change the assembly with the sensor and the motor for the belt retraction.. it didn't work, so I went further and changed the PWB-IO board; works like a charm since then (it's been about 4-5 months, and about 25k prints).. so I suggest you try this too, first, change the sensor and the motor and if nothing is happening, go further and change the PWB-MC (for C350). I hope this helps!
    I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
    • wingit
      • Feb 2011
      • 84
      Thanks, I opened the right side door and cheated the door and the noise was coming from M7 driveing the gears that put the transfer roller in contact with the transfer belt.
      I will try the motor and sensor, first.
      Then then go from there.
      Thank-you Empiru
