USB RECOGNITION ERROR BH
  • seltan
    • 24
    [Misc] USB RECOGNITION ERROR BH
    Dear all,
    Now am facing USB RECOGNITION ERROR in bizhub 282,in the same time RJ45 port is working well,I have checked the copier with minimum 5 system but the same problem is still persistPlease help me if anyone known solition.
  • JustManuals
    • Jan 2006
    • 9838
    Re: USB RECOGNITION ERROR BH
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2630
      What is the file format of the USB drive?
      • mojorolla
        The Wolf
        • 2630
        Sorry, I read your post wrong.
        • RRodgers
          • Jun 2009
          • 1947
          You might just happen to have a bad USB port on your KM. Crack it open and have a look. If it's a bad solder joint that's an easy fix. If it's a bad board... meh... easy fix but going to cost you some time and money.
          • emujo
            • Jun 2009
            • 3009
            Since we are on the subject of USB ports...I routinely use USB powered hubs to free up ethernet connections in my customers offices. Here's the question.. The 463 series has 3 usb ports available 1 for firmware, 1 for attaching an AU, and 1 up front for print from/scan to USB. Port 1 is working to fash firmware, front port will recognize and print scan documents, The only port that will power my USB hub is the firmware port, the other 2 don't seem to have enough power to turn the hub on. Are these USB ports not equipped to supply power or do I have a problem? I have set this up on 501s, 751s, and most of the color boxes with no problems. TIA Emujo
