bizhub 350 and bizhub 500 toner and developer
  • goldencup
    • Nov 2008
    • 366
    Hi! I would like to ask about the toner and developer of bizhub 350 and bizhub 500. Though they are different machine, I would like to know if I can use the toner and developer of bizhub 350 on the machine bizhub 500 and if I can use the toner and developer of bizhub 500 on the machine bizhub 350? Has anyone tried it before? Thank you very much.
  • ineo+6501
    • Mar 2010
    • 262
    Re: bizhub 350 and bizhub 500 toner and developer
    The toner bottles are completely different.
    The Developers are different weights also. The 500 is 625g and the 350 is 300g.
    You will likely cause yourself some serious headaches if you even try.
    I can't see why you would want to if you have access to both sets of consumables?
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      You can use them on any machine you like, they just will not work if it is the wrong one.
