C280 not using fax prefix
  • lanierboy
    • 149
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: C280 not using fax prefix
    As silly as this sounds I believe that all the KonicaMinolta Fax cards only put the prefix in front of programmed speed dials. Manually dialed numbers they expect you to add it yourself.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • lanierboy
      • 149
      Hi
      the machine is not setting the prefix for any numbers, it just ignores the setting, I have never had to put a 99 before a number before only 0 or 9 but the guide says 99 should be ok
      • pepper38_cnd
        • Aug 2005
        • 1075
        There is caution in the FK-502 Service Manual that tells you you must unset the fax option after turning on Prefix and the reset it. Have you done that?
        • lanierboy
          • 149
          Hi All,
          found the answer in the end, if you have a prefix for the fax option, when entering the number you need to place an "e" before the number then the machine knows to use the prefix. ie e01234567898.
          thanks
