Bizhub C6500 Duplex Registration
  • PoonKing5000
    • Jun 2008
    • 111
    I have a machine with about 4million copies on it and the second side of a duplexed copy is about 1/16" shorter (left to right) that the front side. The lead edge lines up pretty good but the trail edge is where you can see the difference. Is there any common cause for this issue (duplex registration roller)?
    Andy
  • PoonKing5000
    • Jun 2008
    • 111
    Re: Bizhub C6500 Duplex Registration
    Anyone???
    • Ianizer
      • Jul 2011
      • 380
      I'll give it a shot.
      Got any samples?
      It's worth mentioning, that's slightly over 1.5mm skew. 2.0mm is your K-M sanctioned tollerance I do believe.
      -I
      My name Peggy.
      You got problem?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • JR2ALTA
          • Feb 2010
          • 2033
          Run the set up test chart in maintenance mode like when you unboxed it One is specifically for second side.
          But...Konica's aren't great with optical registration.
          DITTO the tolerance point above.
          • Ianizer
            • Jul 2011
            • 380
            I've found them to be not horrible, JR, but it might be a matter of how much money you want to throw at the problem (and time being money, I include that in the statement). The specification is probably a function of economics as much as anything.
            We've been able to achieve fairly good registration, but all SW & PM intervals must be kept up to date.
            -I
            My name Peggy.
            You got problem?
            • rrrohan
              • Sep 2011
              • 1977
              I would just give all the rollers in Duplex unit a good clean. so long as its not skewing he customer can just do a image shift adjustment on the fiery
              • Ianizer
                • Jul 2011
                • 380
                Just revisited Mr. 5000's original post. At second read, it looks like a duplex magnification issue.
                Yes, it's not uncommon to see some second-side 1:1 variance, typically most visible with large & thick stock. Simply put, the heat, pressure, and applied electrical charging changes the properties of the paper.
                In this case, Manuals may have posted the more helpful comment.
                -I
                My name Peggy.
                You got problem?
