konica minolta bishub c550 CE password reset...help
  • Darius
    • Aug 2011
    • 13
    i recently change ibt belt and transfer roller unit and i still have a problem with transfer roller unit,the mesage won't go off.
    I understand that in the service mode is the counter for transfer roll and need to be reset............i tryed UTILITY/COUNTER DETAILS stop 0 0 stop 0 1 and in service mode ask for a password and i don't know the password (00000000,12345678,92729272 is not working)
    Can you help me to reset the CE password?
    Thank you
  • minimerlin
    • 851
    Re: konica minolta bishub c550 CE password reset...help
    Thank you
    Ask the tech who changed the password what it is! It must have been changed if the ones you tried do not work.
    Please do not PM me without asking first.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • Darius
        • Aug 2011
        • 13
        Not help, the tech is dead
        • RRodgers
          • Jun 2009
          • 1947
          It's in the manual.
          • Ianizer
            • Jul 2011
            • 380
            Originally posted by RRodgers
            It's in the manual.
            I'm afraid I'll be watching this thread with interest.
            92729272 should be the default password if it's enabled.
            If the password is lost or forgotten, it's a tech support call.
            -I
            My name Peggy.
            You got problem?
            • minimerlin
              • 851
              Sorry to hear that! But you still have a problem as somebody must have changed the password....only way to fix it now is a KM tech support call!
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                certain machines have built in bugs that allow you to go into service mode bypassing the ce password prompt - at which point you can go into security mode and disable the CE password.
                IE, on a c352 once i got straight in to service mode via trouble reset after a fuser error code with the front door open. It may of been a freak occurance or it may be a secret back door sequence of events none the less it allowed me to disable the unknown password prompt. This is not the only machine ive worked on that bypassed the CE prompt involving a bizarre combination of events. I suspect theyre probably bugs
                When all else fails one can do an nvram initialize but youll loose everything and the machine will need to be setup again from scratch.
                • dellt
                  • Dec 2011
                  • 5
                  CE password , is registered in nvram board so you can try Nvram reset procedure maybe it works
