Scan problem With the Konica Minolta C450
  • mindhunter
    • May 2008
    • 147
    hi everybody.I have a scan problem With the Konica Minolta C450 Copier.Thousands of time I set and install the Setting for Scannig On the SMB Mode and it Works.it has just two Possible Way or mode.1- if setting sets correctly When you Press Start Button the "transfering Icon" must appear on the screan and after some while it disappear and scan recived on the Computer.2- if setting doesnt set Correctly it shows a dialog box that says ("Job has been done improperly").But I have a new Problem. When I want to Scan with one of my C450 copier on SMB Mode.Everything is allright and install .But When I press Start Button Sending Icon Apears on the screen and it never disapear and the copier Screen locked (it seems the copier hang and stopped).and I cant Switch between Copy or Box or Fax Buttons for Doing other Purposes.So I must Turn Off the machine With the main Switch.and Actually I cant Scan in this Mode.I want to know Does it happen for anyone else?Is it MFP or NVRAM Problem ? Does Anyone Have any Suggestion for me ? Thank YOu ALL.Im Waiting for Your Usefull Suggestions. Mindhunter.
  • lurker53
    • Mar 2011
    • 22
    Re: Scan problem With the Konica Minolta C450
    Could be a couple of things before jumping to boards.
    I've seen some firewalls make the copiers behave oddly, so ensure that port 445 is open on the target computer (or the network if using an ACL).
    If you've checked the firewall, hit the machine with firmware.
    If it still doesn't work, if I recall corerctly on that machine the NIC is part of the PRCB on the back of the machine.
    That would just be my troubleshooting steps for this kind of problem though. Make sure there's no firewall blocking it, hit it with firmware, and if it still doesn't work start looking at parts.
    • mindhunter
      • May 2008
      • 147
      I dont think its Firewall Problem Because i try with the several computer . even the pc doesnt connect to the machine it has to show "Job has Been done improperly".
      I dont get the point about the NIC part. Can you Explain Where is the NIC ?and what i have to do ?
      And About Firmware how i have to upload new Firmware on this Machin?
      Thanks a lot lurker53 for your guidence.
      im waiting for your reply.
      • mindhunter
        • May 2008
        • 147
        is just lurker Suggestion .
        Anyone else Who has Idea?
        • lurker53
          • Mar 2011
          • 22
          You can install firmware through a CF card or Internet ISW. The service manual explains both methods.
          What I meant by the NIC on the machine is that since it's attached to the board in the back, your worst case scenario is to replace that entire board. Not a cheap option, which is why you always need to try firmware first.
          Did the machine experience a surge?
          Edit: I made the assumption that you've already thoroughly tested the connection as described by 1FRY1. Follow his troubleshooting steps first if you haven't already done so.
          • 1FRY1
            • 51
            So Many questions
            Does it ping and print OK
            Does it store an error in job send history
            What OS are you using to scan to
            Have you tried scanning via a crossover to a laptop or PC
            Does the subnet and gateway match that of the network
            Have you any other MFP's on the network, do they scan OK
            Start with those
            • AjitN
              • Mar 2009
              • 287
              HI
              Please ensure if harddisk is installed & selected as installed in Service Mode --- Syatem 2.
              I have faced omce this problem when hard disk was faukty.
              Hope this helps
              Best Luck
              • mindhunter
                • May 2008
                • 147
                Originally posted by AjitN
                HI
                Hope this helps
                Best Luck
                thanks ajitN
                I will try it and ill answer you .
                thanks for your help
                • mindhunter
                  • May 2008
                  • 147
                  Originally posted by 1FRY1
                  So Many questions
                  1-Does it ping and print OK
                  2-Does it store an error in job send history
                  3-What OS are you using to scan to
                  4-Have you tried scanning via a crossover to a laptop or PC
                  5-Does the subnet and gateway match that of the network
                  6-Have you any other MFP's on the network, do they scan OK
                  Start with those
                  1- yes it ping when i try via a loptop.even I can access from the refrence(in Direct SMB) of copier to the pc.
                  2- No it just hang and never save any job error.
                  3-I use windows XP and seven of microsoft.
                  4-yes . i use both but it didnt work.
                  5-yes Subnet and gateway is match.
                  6-yes.Other MFPs Work correctly.
                  • mindhunter
                    • May 2008
                    • 147
                    thanks.
                    I have Other MFP in my office. So i think after all of these suggestions.i have to change part by part with my new MFP to detect problem.
                    Just can you show NIC With the attach a picture of it ?
                    • dallas
                      • Jun 2008
                      • 115
                      Before you change some parts, test the following.
                      - Create a Box
                      - Scan into it
                      - If it's not work, HDD is in the most cases faulty
                      - If it's work, set HDD to "not installed" in Service Mode
                      - Restart the Engine and perform a SMB Scan
                      - Works ... smile and change HDD
                      - If not ... go back to start ;-)
                      • DUKEY
                        • Sep 2008
                        • 56
                        Hey Guys, Hate to jump in here! But I need to see if anyone is interested in a brand new Transfer Belt and Fuser Unit, Part's 4049-523 and 4049-212 for this model? I'm trying to figure out how to make my own thread! sorry again for interupting Dukey PS SEND ME A MESSAGE IF YOU ARE!
